Convert your existing serial cables into null modem cables using null modem adapters from C2G. A quick and easy fix for your DTE or DCE incompatibilities, connecting two RS232 serial ports has never been so easy. Each cable will effectively cross the data transmission lines.
- C2G - null modem adapter - DB-9 to DB-9
- Null modem adapter
- Technology
- Shielded
- Molded
- Connector
- 9 pin D-Sub (DB-9) - male
- Connector (Second End)
- 9 pin D-Sub (DB-9) - female
- Grey
- Limited lifetime warranty
- Technology
- Shielded
- Molded
- Grey
- Connector
- RoHS
