Mini gender changers from C2G provide the full benefit of a gender changer at a fraction of the space. These low-profile gender changers will quickly and easily convert the gender of any parallel, serial, game/midi or video port. In addition, they can be used to splice together two existing cables.
Compact design
The Mini Gender Changer by C2G boasts a low-profile design, making it an ideal solution for setups where space is at a premium. Its compact size ensures it can fit into tight spaces without compromising connectivity. -
Versatile connectivity
Featuring female 37 pin D-Sub (DB-37) connectors on both ends, this gender changer is designed to seamlessly connect parallel and serial cables, enhancing the flexibility of your PC's connectivity options. -
Robust compatibility
Designed with PC compatibility in mind, this gender changer ensures a reliable connection between devices, supporting a wide range of applications and setups.
- C2G Mini Gender Changer - gender changer - DB-37 to DB-37
- Gender changer
- Low profile
- Connector
- 37 pin D-Sub (DB-37) - female
- Connector (Second End)
- Gender changer
- Low profile
- Connector
- RoHS
