C2G DB37 F/F Mini Gender Changer (Coupler)
Quicklinx: 685TWS00 Mfr#: 81519
Mini gender changers from C2G provide the full benefit of a gender changer at a fraction of the space. These low-profile gender changers will quickly and easily convert the gender of any parallel, serial, game/midi or video port. In addition, they can be used to splice together two existing cables.
  • Compact design
    The Mini Gender Changer by C2G boasts a low-profile design, making it an ideal solution for setups where space is at a premium. Its compact size ensures it can fit into tight spaces without compromising connectivity.
  • Versatile connectivity
    Featuring female 37 pin D-Sub (DB-37) connectors on both ends, this gender changer is designed to seamlessly connect parallel and serial cables, enhancing the flexibility of your PC's connectivity options.
  • Robust compatibility
    Designed with PC compatibility in mind, this gender changer ensures a reliable connection between devices, supporting a wide range of applications and setups.
C2G Mini Gender Changer - gender changer - DB-37 to DB-37
Gender changer
Low profile
Connector
37 pin D-Sub (DB-37) - female
Connector (Second End)
Gender changer
Low profile
Connector
RoHS
