C2G Centronics 50 F/F Gender Changer (Coupler)
Quicklinx: 685GWS00 Mfr#: 81508
£5.98 ex VAT
£7.17 inc VAT
Centronics gender changer from C2G easily lets you change the gender of a 50-Pin connectors. With the changer, you will be able to use your existing Centronics cable by altering the port connection on your device or cable. In addition, it can be used to splice together two existing cables.
C2G SCSI external gender converter
Shielded
Molded
Connector
50 PIN Centronics - female
Connector (Second End)
Storage Cable Type
Shielded
Molded
Connector
RoHS
Brand: C2G
