C2G CablesToGo 1.2m PWR EXT CBL C13-C14 16AWG
Quicklinx: 7B9JWS00 Mfr#: 81137
Plug in the power extension cord to make your work environment more flexible and efficient. The female connector plugs directly into device, and the male connector plugs into an existing cable. This heavy-duty 16 AWG cord features a fully molded design for maximum durability and long life. Compatible for monitors, scanners, printers, and other devices that use a 3-pin shroud power connector.
C2G - power extension cable - power IEC 60320 C13 to IEC 60320 C14 - 1.2 m
Power extension cable
Length
1.2 m
Connector
Power IEC 60320 C13
Connector (Second End)
Power IEC 60320 C14
Rated Voltage
AC 250 V
American Wire Gauge (AWG)
16
Rated Voltage
AC 250 V
Length
1.2 m
Connector
Power IEC 60320 C13
Power IEC 60320 C14
RoHS
