Brand
C2G Audio Isolation Transformer
Quicklinx: 67WXWS00 Mfr#: 80449
Accessory Type: Installation Component
£37.10 ex VAT
£44.52 inc VAT
Ground loop isolation transformers from C2G connect easily into your A/V system and break the ground path through cables between components. Start at the component last installed before the ground loop was discovered and connect the isolation transformer at different ends of the A/V cable until the ground loop is gone. They offer ground loop isolation transformers for composite video, S-video and component video applications.
C2G Stereo Audio Isolation Transformer - ground loop isolator
Ground loop isolator
2.5 cm x 10.2 cm x 3.8 cm
113 g
2.5 cm
10.2 cm
3.8 cm
113 g
Lifetime
Brand: C2G
