C2G 8in DisplayPort to HDMI/VGA Adapter - White
Quicklinx: DWKHWS00 Mfr#: 80938
Colours:
Send a video signal from a tablet, laptop computer, or another source device with a DisplayPort output port to a projector, monitor, or HDTV with an HDMI or VGA input port. This compact adapter converter is an ideal solution for use in schools, conference rooms, or other work spaces that may utilize assorted displays with varying inputs.
[B]Convenience[/B].
Be prepared for any meeting, presentation, or event with the full confidence that you have the right connections in an compact design. The DisplayPort to HDMI or VGA adapter converter allows you to connect a DisplayPort equipped laptop or tablet to a projector, monitor, or HDTV with an HDMI or VGA input port. The compact design of this adapter converter makes it a perfect fit for BYOD (Bring Your Own Device) applications in education or corporate environments.
[B]Performance[/B].
This adapter converter carries a digital audio/video signal, supporting up to a 4K30 resolution for HDMI, up to 1920x1200 for VGA and meets the requirement of high performance applications. With plug and play convenience, the adapter converter does not require drivers for install and the device is powered through DisplayPort bus power, so no additional power adapters are needed. The dongle-style adapter converter reduces strain on the video port. The cable between the DisplayPort connection and the adapter converter provides strain relief that protects the port from strain damage as cords are moved.
  • Colour
    White
  • Warranty
    3 Years
  • Connector 1
    (1) DisplayPort Male
  • Connector 2
    (1) HDMI Female, (1) VGA Female
C2G 20cm DisplayPort to HDMI or VGA Female Adapter Converter - 4K support - White - adapter - DisplayPort / HDMI / VGA - 20.3 cm
Cable
Adapter - DisplayPort / HDMI / VGA
Shielded
American Wire Gauge (AWG)
32
Length
20.3 cm
White
Connectors
DisplayPort - male (input)
Connectors (Second End)
HDMI - female (output) , 15 pin D-Sub (DB-15) - female (output)
4K support
3-year warranty
Cable Type
Adapter 4K support
Interface Supported
Shielded
32
Jacket Material
PVC
Shielding Material
Aluminium-magnesium alloy
Length
20.3 cm
60+ Hz refresh rate
White
Connectors
20 pin DisplayPort - male (input)
19 pin HDMI Type A - female (output) , 15 pin D-Sub (DB-15) - female (output)
UL 20276, RoHS 2 (2011/65/EU)
Limited warranty - 3 years
