C2G 7m ST/ST LSZH Duplex 62.5/125 Multimode Fibre Patch Cable - Orange
Quicklinx: 6C0YWS00 Mfr#: 85211
With ST to ST termination, this high quality fibre optic patch cable is specifically designed for Fast Ethernet, fibre channel, ATM and Gigabit Ethernet applications. The ST connector features a bayonet locking system. The Low Smoke Zero Halogen (LSZH / LS0H) jacket is composed from materials that lessen the smoke and halogen emissions when the cable is exposed to extreme temperatures. This reduces the amount of harmful toxic and corrosive gases that cabling made with plastic materials would otherwise emit into the air during combustion. This construction makes LSZH cables ideal for use where the protection of people and equipment from harmful corrosive gases is absolutely critical. The patented injection moulding process provides each connection greater durability in resisting pulls, strains and impacts from cabling installs.
  • Enhanced safety
    The Low-Smoke Zero-Halogen (LSZH) jacket material ensures enhanced safety by reducing the amount of toxic and corrosive gas emitted during combustion.
  • High-quality connectivity
    Equipped with ST multi-mode connectors on both ends, this patch cable provides high-quality connectivity and performance for fiber optic networks.
  • Durable design
    Featuring a core/cladding diameter of 62.5 / 125 micron and a robust construction, this cable is designed for long-lasting use in demanding network environments.
C2G Low-Smoke Zero-Halogen - patch cable - 7 m - orange
Patch cable
Fibre optic
Type of Fibre Optics
Multimode
Length
7 m
Core / Cladding Diameter
62.5 / 125 micron
Connector
2 x ST multi-mode - male
Connector (Second End)
Orange
Network Cable Type
Patch cable
Fibre optic
Multimode
Jacket Material
Low Smoke Zero Halogen (LSZH)
Fibre Qty
2
62.5 / 125 micron
Length
7 m
Orange
Connector
RoHS
