C2G 7m Cat6 550 MHz Snagless Patch Cable - White
Quicklinx: 6BRQWS00 Mfr#: 83491
For fast Ethernet and Gigabit computer networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat6 TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimises Near-End Crosstalk (NEXT) levels. The moulded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief. Available in a variety of colours to easily color-coded your network installation. Each cable is individually labelled with the length for ease of use.
  • High-speed connectivity
    Experience fast data transfer speeds with the Cat6 Booted Unshielded (UTP) Network Patch Cable, tested up to 550 MHz to ensure reliable high-speed Internet and network connectivity.
  • Durable design
    Constructed with a high-quality PVC jacket and 24 AWG American Wire Gauge for enhanced durability and longevity, this patch cable is designed to withstand daily use.
  • Universal compatibility
    Featuring RJ-45 male connectors on both ends and a T568B wiring scheme, this network patch cable is compatible with a wide range of devices, ensuring a seamless connection for your PC and other compatible hardware.
C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 7 m - white
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Molded, snagless, stranded
Length
7 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
White
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Plated Connector
Gold
Length
7 m
White
Connector
RJ-45 - male
RJ-45 - male
Up to 550 MHz
