For fast Ethernet and Gigabit computer networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat6 TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimises Near-End Crosstalk (NEXT) levels. The moulded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief. Available in a variety of colours to easily color-coded your network installation. Each cable is individually labelled with the length for ease of use.
High-speed connectivity
Experience fast data transfer speeds with the Cat6 Booted Unshielded (UTP) Network Patch Cable, tested up to 550 MHz to ensure reliable high-speed Internet and network connectivity. -
Durable design
Constructed with a high-quality PVC jacket and 24 AWG American Wire Gauge for enhanced durability and longevity, this patch cable is designed to withstand daily use. -
Universal compatibility
Featuring RJ-45 male connectors on both ends and a T568B wiring scheme, this network patch cable is compatible with a wide range of devices, ensuring a seamless connection for your PC and other compatible hardware.
- C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 7 m - white
- Patch cable - CAT 6
- Technology
- Wiring Scheme
- T568B
- Molded, snagless, stranded
- Length
- 7 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- White
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Plated Connector
- Gold
- Length
- 7 m
- White
- Connector
- RJ-45 - male
- RJ-45 - male
- Up to 550 MHz
