C2G 7m Cat6 550 MHz Snagless Patch Cable - Black
Quicklinx: 6BQ9WS00 Mfr#: 83411
For fast Ethernet and Gigabit computer networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat6 TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimises Near-End Crosstalk (NEXT) levels. The moulded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief. Available in a variety of colours to easily color-coded your network installation. Each cable is individually labelled with the length for ease of use.
  • High-quality connectivity
    The Cat6 Booted Unshielded (UTP) Network Patch Cable by C2G is designed with a 24 American Wire Gauge (AWG) and a durable PVC jacket, ensuring a reliable connection and reliable performance for all networking needs.
  • Enhanced performance
    With a tested frequency of up to 550 MHz, this patch cable supports high-speed data transfer rates, making it suitable for various applications, including video streaming, high-speed Internet, and server connections.
  • Universal compatibility
    Featuring RJ-45 male connectors on both ends and complying with T568B wiring schemes, this network patch cable ensures seamless compatibility with PCs and a wide range of network equipment.
C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 7 m - black
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Molded, snagless, stranded
Length
7 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
24
Plated Connector
Gold
Length
7 m
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 550 MHz
