Cables To Go's Cat6 crossover cables are perfect for distributing data, voice, video and connecting network switches and hubs without an uplink port to other switches and hubs. These 550MHz rated patch cables ensure that you always have the necessary throughput to handle bandwidth-intensive applications. Note:These cables are for 10/100 ethernet only and will not work for gigabit ethernet as only two pairs of this cable are crossed.
Our new moulded, snag-free "clip" prevents unwanted cable snags during installation and doesn't impair the ability to insert and remove the connector from the port. It also provides extraordinary strain-relief, so that the cable is not damaged even when pulled excessively.
Enhanced connectivity
The Cat6 Booted Unshielded (UTP) Crossover Patch Cable by C2G is designed to connect two devices directly, such as computers to computers, ensuring reliable connectivity and improved network performance. With its T568B wiring scheme and gold-plated RJ-45 connectors, this cable provides a secure connection with minimal signal loss, making it ideal for gaming, file transfers, and network testing environments. -
High-quality construction
Constructed with a durable PVC jacket and an American Wire Gauge (AWG) of 24, this crossover cable is built to withstand rigorous use in any setting. The cable's flexibility and resilience prevent it from damage and wear, ensuring a long-lasting solution for your networking needs. -
Reliable performance
Tested to support frequencies up to 550 MHz, this CAT 6 cable facilitates high-speed data transmission and bandwidth-intensive applications without any compromise on quality. Its unshielded twisted pair (UTP) technology minimizes noise and interference, providing a clear and stable signal.
- C2G Cat6 Booted Unshielded (UTP) Crossover Patch Cable - crossover cable - 7 m - red
- Crossover cable - CAT 6
- Technology
- Wiring Scheme
- T568B
- Molded, snagless, stranded
- Length
- 7 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Red
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Plated Connector
- Gold
- Length
- 7 m
- Red
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS - up to 550 MHz
