Protect your high speed network from noise and electromagnetic interference when you connect with our shielded Cat5e patch cable. Constructed from high quality cable and plugs, this design minimises Near-End Crosstalk (NEXT) levels. The moulded boot provides extra strain relief and durability. Available in a variety of colours to easily colour-code your network installation.
Enhanced connectivity
Equipped with gold-plated RJ-45 connectors, this Cat5e Booted Shielded (STP) Network Patch Cable ensures a reliable connection with minimal Near-End Crosstalk (NEXT), offering a stable and secure networking experience. -
Durable design
The cable features a robust PVC jacket and is constructed with a 24 AWG, designed to withstand the rigors of daily use while maintaining optimal performance. -
Versatile compatibility
Designed to meet the T568B wiring scheme, this patch cable is compatible with a wide range of PCs, ensuring a seamless integration into existing network setups.
- C2G Cat5e Booted Shielded (STP) Network Patch Cable - patch cable - 7 m - white
- Patch cable - CAT 5e
- Technology
- Shielded twisted pair (STP)
- Wiring Scheme
- T568B
- Wires per Cable
- 8 wires
- Molded, minimised Near-End Crosstalk (NEXT)
- Length
- 7 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- White
- Limited lifetime warranty
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Plated Connector
- Gold
- Length
- 7 m
- White
- Connector
- RJ-45 - male
- RJ-45 - male
