C2G 7m Cat5E 350 MHz Snagless Patch Cable - Purple
Quicklinx: 6BVYWS00 Mfr#: 83664
For Fast Ethernet networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat5e TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs are bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimizes Near-End Crosstalk (NEXT) levels. The molded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief.
  • High-quality connectivity
    Featuring a high-grade PVC jacket and 24 AWG American Wire Gauge construction, this Cat5e Booted Unshielded (UTP) Network Patch Cable ensures durable and reliable connectivity for all your networking needs. The gold-plated RJ-45 connectors provide a secure and corrosion-resistant connection, enhancing signal integrity and performance.
  • Enhanced performance
    Designed to support a tested frequency of up to 350 MHz, this patch cable is perfect for high-speed data applications. The T568B wiring scheme and UTP technology minimize interference, providing fast and stable network connections for PCs and other compatible devices.
  • Universal compatibility
    With male RJ-45 connectors on both ends, this network patch cable offers broad compatibility with a wide range of devices. Its adherence to RoHS compliant standards ensures environmentally safe materials are used, making it a responsible choice for your networking requirements.
C2G Cat5e Booted Unshielded (UTP) Network Patch Cable - patch cable - 7 m - purple
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Molded, snagless, stranded
Length
7 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Purple
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
7 m
Purple
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 350 MHz
