For Fast Ethernet networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat5e TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs are bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimizes Near-End Crosstalk (NEXT) levels. The molded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief.
High-quality connectivity
Featuring a high-grade PVC jacket and 24 AWG American Wire Gauge construction, this Cat5e Booted Unshielded (UTP) Network Patch Cable ensures durable and reliable connectivity for all your networking needs. The gold-plated RJ-45 connectors provide a secure and corrosion-resistant connection, enhancing signal integrity and performance. -
Enhanced performance
Designed to support a tested frequency of up to 350 MHz, this patch cable is perfect for high-speed data applications. The T568B wiring scheme and UTP technology minimize interference, providing fast and stable network connections for PCs and other compatible devices. -
Universal compatibility
With male RJ-45 connectors on both ends, this network patch cable offers broad compatibility with a wide range of devices. Its adherence to RoHS compliant standards ensures environmentally safe materials are used, making it a responsible choice for your networking requirements.
- C2G Cat5e Booted Unshielded (UTP) Network Patch Cable - patch cable - 7 m - purple
- Patch cable - CAT 5e
- Technology
- Wiring Scheme
- T568B
- Wires per Cable
- 8 wires
- Molded, snagless, stranded
- Length
- 7 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Purple
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Plated Connector
- Gold
- Length
- 7 m
- Purple
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS - up to 350 MHz
