C2G 7m Cat5E 350 MHz Snagless Patch Cable - Pink
Quicklinx: 6BTXWS00 Mfr#: 83622
For Fast Ethernet networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat5e TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs are bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimizes Near-End Crosstalk (NEXT) levels. The molded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief.
  • Enhanced connectivity
    The Cat5e Booted Unshielded (UTP) Network Patch Cable by C2G is designed with high-quality 24 AWG copper wires, ensuring reliable connectivity and improved signal integrity for your network. Its gold-plated RJ-45 connectors provide a secure and corrosion-resistant connection, enhancing the overall performance of your network infrastructure.
  • Durable design
    Featuring a robust PVC jacket material, this network patch cable is built to withstand the rigors of daily use in various environments. The boot cover adds extra strain relief that protects the cable and the clip from damage during installation, making it a durable choice for both home and office networking needs.
  • High-speed performance
    With a tested frequency of up to 350 MHz, this patch cable supports fast data transfer rates, making it suitable for a wide range of applications, including Internet, streaming, and gaming. Its unshielded twisted pair (UTP) technology minimizes noise and interference, providing a stable and clear connection.
C2G Cat5e Booted Unshielded (UTP) Network Patch Cable - patch cable - 7 m - pink
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Molded, snagless, stranded
Length
7 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Pink
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
7 m
Pink
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 350 MHz
