For Fast Ethernet networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat5e TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs are bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimizes Near-End Crosstalk (NEXT) levels. The molded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief.
Enhanced connectivity
The Cat5e Booted Unshielded (UTP) Network Patch Cable by C2G is designed with high-quality 24 AWG wires and a durable PVC jacket, ensuring reliable connectivity and longevity. Its gold-plated RJ-45 connectors provide a secure and corrosion-resistant connection, making it a suitable choice for various networking requirements. -
High-speed performance
With a tested frequency of up to 350 MHz, this patch cable supports fast data transfer rates, making it suitable for Internet, video streaming, and gaming applications. The T568B wiring scheme and UTP technology help in reducing interference, ensuring clear and stable transmission. -
Universal compatibility
Designed to meet RoHS compliance standards, this network patch cable is compatible with PCs and a wide range of devices. Its universal connectivity makes it a suitable solution for both home and office networking needs.
- C2G Cat5e Booted Unshielded (UTP) Network Patch Cable - patch cable - 7 m - grey
- Patch cable - CAT 5e
- Technology
- Wiring Scheme
- T568B
- Wires per Cable
- 8 wires
- Molded, snagless, stranded
- Length
- 7 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Grey
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Plated Connector
- Gold
- Length
- 7 m
- Grey
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS - up to 350 MHz
