C2G 7m 3.5mm M/M Stereo Audio Cable
Quicklinx: 63QDWS00 Mfr#: 80120
The 3.5mm stereo audio cable is specifically designed for quality computer audio applications. It attaches a PC sound card, portable CD player or any mini-stereo audio device with 3.5mm jacks to a multimedia speaker. This cable features two copper conductors and a drain wire. The conductors and drain wire are wrapped with a braided shield which prevents unwanted EMI/RFI interference. Fully moulded nickel-plated connectors provide excellent strain relief for durable use.
Product Specifications
  • Color: Black
  • UPC: 757120801207
  • Warranty: Lifetime
  • Weight: 0.106 KG
  • Length: 7.00 Meter
  • Volume: 195.0 CCM
  • Connectors: 3.5mm Stereo Male to 3.5mm Stereo MaleFoil shielded
  • Nickel-plated connectors
  • Warranty
    Lifetime
  • Colour
  • Cable Length
    7.00 Meter
C2G audio cable - 7 m
Cable
Audio cable
Shielded
American Wire Gauge (AWG)
29
Length
7 m
Connector
Mini-phone stereo 3.5 mm - male
Connector (Second End)
Stranded conductor, moulded
Cable Type
Audio cable
Shielded
29
Shielding Material
Foil
Length
7 m
Plated Connector
Nickel
Connector
RoHS
