C2G 5m Value Component Video Cable
Quicklinx: 67PPWS00 Mfr#: 80013
Component video cables from C2G are designed for connecting high definition DVD players and high-end televisions. These cost-conscious cables are high quality and deliver a crisp, clear picture for less. Component video cables are able to bypass the TV's Y/C separator and color decoder, routing the color information directly into the TVs matrix decoder. By sending the pure DVD component video signal directly to a component video input-equipped display device, the DVD signal forgoes the extra processing that would normally degrade the image. The result is a vastly increased image quality, with incredibly lifelike colors and crisp detail.
C2G Value Series video cable - component video - 5 m
Cable
Video cable - component video
Shielded
Length
5 m
Connector
3 x RCA - male
Connector (Second End)
3 x RCA - male
Colour-coded connectors, moulded
Cable Type
Video cable
Interface Supported
Component video
Shielded
Length
5 m
Plated Connector
Nickel
Connector
3 x RCA - male
3 x RCA - male
Limited warranty - lifetime
