USB A/B cables from C2G are designed to connect from the USB port on your hub, PC or Mac to your USB device. This fully-rated USB cable provides transfer rates up to 480 Mbps, and easily attaches to any USB device. It is compatible with USB 1.0, 1.1 and 2.0.
- C2G - USB cable - USB to USB Type B - 5 m
- USB cable
- Technology
- Double shielded twisted pair
- Length
- 5 m
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 4 pin USB Type B - male
- USB / USB 2.0
- White
- USB cable
- Technology
- Length
- 5 m
- White
- Connector
- USB / USB 2.0, Plug and Play, RoHS
