Plug in the UL listed Universal Power Cord from C2G to replace your overused or misplaced power cables. Universal Power Cords are designed to work with most PCs, monitors, scanners, printers and other devices that use the 3-pin shroud power connector. All C2G power cables feature a fully molded design that provides maximum durability and long-life.
Versatile compatibility
Designed to power PCs, this universal power cord is equipped with a power BS 1363 male connector on one end and a power IEC 60320 C13 on the other, ensuring a wide range of compatibility with various devices. -
Durable design
Constructed with an 18 American Wire Gauge (AWG) cable, this power cord is built for durability and reliable performance, ensuring a stable power supply to your devices.
- C2G Universal Power Cord - power cable - BS 1363 to power IEC 60320 C13 - 5 m
- Power cable
- Molded, 90° connector
- Length
- 5 m
- Connector
- Power BS 1363 - male
- Connector (Second End)
- Power IEC 60320 C13
- Black
- Limited lifetime warranty
- Power cable
- American Wire Gauge (AWG)
- 18
- Length
- 5 m
- Black
- Connector
