C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915LWS00 Mfr#: 80555
Type: HDMI
Length: 5m
£21.48 ex VAT
£25.77 inc VAT
Experience ULTRA HD (4K) displays with this Select High-Speed HDMI Cable which provides a fast and reliable connection for home theatre or desktop audio video applications requiring high speed HDMI capabilities and video resolutions up to 4K (2160p). This High-Speed HDMI Cable supports the latest HDMI features including Ultra HD, 4K at 50/60 (2160p), up to 32 audio channels and wide angle theatrical 21:9 video aspect ratio and is compatible with any modern Laptop, Chromebook, HDTV or gaming console, including Sony PlayStation 4 (PS4) and Microsoft Xbox ONE. The cable is also backwards compatible with PlayStation 3 (PS3) and Xbox 360. The CL2 rated cable jacket is designed to meet the requirements for in-wall installations. The Ethernet capabilities of the cable allow users to connect multiple Ethernet-enabled HDMI devices through a single Ethernet connection. This fully-functional, high bandwidth cable is tested to perform at industry standards and is backed by a lifetime warranty. Note: Both the source device and display must support a HDMI feature in order to pass that particular feature through this cable.
  • HDMI Feature Note
    Both the source device and display must support an HDMI feature in order to pass that feature through this cable
  • Multi-Stream Audio
    Simultaneous delivery of multi-stream audio to multiple users (up to 4)
  • Wide Angle Support
    Support for the wide angle theatrical 21:9 video aspect ratio
  • Dynamic Synchronization
    Dynamic synchronization of video and audio streams
  • CEC Control
    CEC extensions for control of consumer electronics devices through a single control point
  • Compatibility
    Compatible with both Sony PlayStation 4 (PS4) and MicroSoft XBOX ONE consoles. It's also backwards compatible with PlayStation 3 (PS3) and XBOX 360
  • Colour
  • Warranty
    Lifetime
  • Connector 1
    (1) HDMI Male
  • Connector 2
    (1) HDMI Male
C2G 5m Select High Speed HDMI Cable with Ethernet - 4K - UltraHD - HDMI with Ethernet cable - 5 m
Cable
Shielded
American Wire Gauge (AWG)
28
Length
5 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
Cable Type
Shielded
28
Jacket Material
PVC
Shielding Material
Aluminium foil with braid
Impedance
100 Ohm
Length
5 m
Plated Connector
Gold
Connector
19 pin HDMI Type A - male
UL
Limited warranty - lifetime
Type: HDMI
Length: 5m
Brand: C2G
Price Range Ex VAT: 0 - 50
