C2G 5m Pro-Audio XLR M To XLR F
Quicklinx: 67WFWS00 Mfr#: 80380
Type: Audio
Length: 5m
£10.03 ex VAT
£12.03 inc VAT
Use this XLR to XLR cable to connect unbalanced sources to balanced XLR inputs. This pro-audio cable is made from 22 AWG twisted pair audio cable under an aluminum foil shield and 60% copper braid for maximum shielding from noise. The highly flexible 7mm PVC jacket reduces the risk of the cable kinking and damaging the conductors.
Bright nickel plating on solid brass connectors resists wear from reconfiguring and moving equipment from one venue to another. Spring strain relief on the plug and a chuck strain relief inside the XLR reduce the effects of age on the solder joints and contacts.
C2G Pro-Audio audio cable - 5 m
Cable
Audio cable
Shielded foiled twisted pair (SFTP)
American Wire Gauge (AWG)
22
Length
5 m
Connector
XLR3 - male
Connector (Second End)
XLR3 - female
Cable Type
Audio cable
22
Jacket Material
Flexible PVC
Shielding Material
Foil with copper braid
Length
5 m
Plated Connector
Nickel
Connector
3 pin XLR - male
3 pin XLR - female
RoHS
Type: Audio
Length: 5m
Brand: C2G
Price Range Ex VAT: 0 - 50
