This cable is an ideal solution for connecting the DisplayPort output of a laptop to a computer monitor which accepts a DisplayPort input. This cable carries a digital audio/video signal and the connectors feature latches which secure the cable in the port. Support of a Reduced Bit Rate (RBR) bandwidth means that this cable can carry up to a 1920x1080 resolution. Built to DisplayPort 1.2 standards, this cable meets the requirements of high performance applications.
High compatibility
Designed to connect seamlessly with PCs, this 5m DisplayPort Cable with Latches ensures a reliable connection between your computer and display devices. -
Secure connection
Featuring latches on both ends, the cable provides a secure, stable connection that prevents accidental disconnections, ensuring uninterrupted viewing and gaming experiences. -
High-quality visuals
Compliant with DisplayPort 1.2 standards, this cable supports 8K UHD and 4K resolutions, delivering crisp, vivid visuals for an enhanced viewing experience.
 - C2G 5m DisplayPort Cable with Latches 8K UHD M/M - 4K - Black - DisplayPort cable - 5 m
 - DisplayPort cable
 - Latched
- Length
 - 5 m
- Connector
 - DisplayPort - male
- Connector (Second End)
 - Black
 - Limited lifetime warranty
 - DisplayPort cable
 - Latched
- Length
 - 5 m
 - Black
- Connector
 - 20 pin DisplayPort - male
 - DisplayPort 1.2
