Easily extend your cables at a lower cost than buying a new cable. All 25 lines are wired straight through pin-to-pin for ease of compatibility. Each cable is foil shielded for EMI/RFI protection, and is available fully snagless with thumbscrew connectors for a fast, easy connection every time.
- C2G serial / parallel extension cable - DB-25 to DB-25 - 5 m
- Serial / parallel extension cable
- Technology
- Shielded
- Molded, thumbscrews
- Length
- 5 m
- Connector
- 25 pin D-Sub (DB-25) - male
- Connector (Second End)
- 25 pin D-Sub (DB-25) - female
- Technology
- Shielded
- Length
- 5 m
- Connector
- RoHS
