For voice/data/video distribution, this cable it will handle bandwidth-intensive applications up to 550 MHz. Meets all Cat6 TIA/EIA-568-B-2.1, draft 9 standards, and drastically reduces both impedance and structural return loss (SRL) when compared to standard 100 MHz wire. Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point.
High-quality connectivity
The Cat6 Booted Unshielded (UTP) Network Patch Cable by C2G is designed with a 24 AWG and a durable PVC jacket, ensuring reliable connectivity and longevity. Its gold-plated RJ-45 connectors provide a secure connection, minimizing interference and maximizing signal quality for superior network performance. -
Enhanced performance
With a tested frequency of up to 550 MHz, this patch cable supports high-speed data transfer rates, making it ideal for various networking applications. The T568B wiring scheme and UTP technology further enhance its performance, ensuring efficient data transmission across networks. -
Universal compatibility
Designed to meet RoHS compliant standards, this network patch cable is compatible with PCs, ensuring a wide range of device connections. Its male RJ-45 connectors on both ends allow for easy and straightforward network setup, making it a versatile choice for any networking requirement.
- C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 5 m - red
- Patch cable - CAT 6
- Technology
- Wiring Scheme
- T568B
- Molded, snagless, stranded
- Length
- 5 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Red
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Plated Connector
- Gold
- Length
- 5 m
- Red
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS - up to 550 MHz
