For voice/data/video distribution, this cable it will handle bandwidth-intensive applications up to 550 MHz. Meets all Cat6 TIA/EIA-568-B-2.1, draft 9 standards, and drastically reduces both impedance and structural return loss (SRL) when compared to standard 100 MHz wire. Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point.
High-quality connectivity
The Cat6 Booted Unshielded (UTP) Network Patch Cable by C2G is designed with a high-quality PVC jacket and gold-plated connectors to ensure reliable connectivity and durability. Its American Wire Gauge (AWG) of 24 supports efficient data transmission, making it an ideal choice for various networking requirements. -
Enhanced performance
Featuring a tested frequency of up to 550 MHz, this patch cable is engineered to facilitate high-speed data transfer for applications requiring optimal performance. The T568B wiring scheme and UTP technology help in reducing noise and crosstalk, enhancing your network's overall efficiency.
- C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 5 m - yellow
- Patch cable - CAT 6
- Technology
- Wiring Scheme
- T568B
- Molded, snagless, stranded
- Length
- 5 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Yellow
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Plated Connector
- Gold
- Length
- 5 m
- Yellow
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS - up to 550 MHz
