C2G 5m Cat6 550 MHz Snagless Patch Cable - Purple
Quicklinx: 6BV6WS00 Mfr#: 83635
For voice/data/video distribution, this cable it will handle bandwidth-intensive applications up to 550 MHz. Meets all Cat6 TIA/EIA-568-B-2.1, draft 9 standards, and drastically reduces both impedance and structural return loss (SRL) when compared to standard 100 MHz wire. Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point.
  • High-speed connectivity
    Experience seamless network performance with the Cat6 Booted Unshielded (UTP) Network Patch Cable, designed to support tested frequencies up to 550 MHz. This ensures optimal performance for your PC's networking capabilities, ideal for high-speed Internet, streaming, and gaming.
  • Durable design
    Constructed with a 24 American Wire Gauge (AWG) and a robust PVC jacket, this patch cable is built for durability and long-term use. The gold-plated RJ-45 connectors provide a reliable connection that resists corrosion, ensuring your network setup remains uninterrupted.
  • Universal compatibility
    Featuring a T568B wiring scheme and male RJ-45 connectors on both ends, this network patch cable is compatible with a wide range of devices and networks. Its universal design makes it a versatile addition to any networking setup, supporting seamless integration with your existing infrastructure.
C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 5 m - purple
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Molded, snagless, stranded
Length
5 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Purple
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
24
Plated Connector
Gold
Length
5 m
Purple
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 550 MHz
