C2G 5m Cat6 550 MHz Snagless Patch Cable - Blue
Quicklinx: 6BPXWS00 Mfr#: 83390
For fast Ethernet and Gigabit computer networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat6 TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimises Near-End Crosstalk (NEXT) levels. The moulded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief. Available in a variety of colours to easily color-coded your network installation. Each cable is individually labelled with the length for ease of use.
  • High-performance connectivity
    Experience seamless network performance with the Cat6 Booted Unshielded (UTP) Network Patch Cable, designed to support tested frequencies up to 550 MHz. This ensures high-speed data transmission for your computing needs, making it suitable for both home and office environments.
  • Durable design
    Constructed with a 24 American Wire Gauge (AWG) and a robust PVC jacket material, this patch cable is built to last. The gold-plated connectors not only provide a reliable connection but also resist corrosion, ensuring a durable, high-quality connection between your devices.
  • Universal compatibility
    Designed to be compatible with PCs, this network patch cable features RJ-45 male connectors on both ends, making it highly versatile for connecting a wide range of devices. Whether you're setting up a home network or connecting devices in an office, this cable is suitable for the task.
C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 5 m - blue
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Molded, snagless, stranded
Length
5 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
Network Cable Type
Patch cable - CAT 6
Jacket Material
PVC
24
Plated Connector
Gold
Length
5 m
Blue
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 550 MHz
