C2G 5m Cat6 550 MHz Snagless Patch Cable - Black
Quicklinx: 6BQ8WS00 Mfr#: 83410
Length: 5m
Colour: Black
More than 50 In Stock
£4.38 ex VAT
£5.25 inc VAT
For fast Ethernet and Gigabit computer networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat6 TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimises Near-End Crosstalk (NEXT) levels. The moulded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief. Available in a variety of colours to easily color-coded your network installation. Each cable is individually labelled with the length for ease of use.
  • High-quality connectivity
    The Cat6 Booted Unshielded (UTP) Network Patch Cable by C2G is designed with a high-quality PVC jacket and gold-plated connectors to ensure durable and reliable connectivity for all networking needs. With its T568B wiring scheme and UTP technology, this cable provides a dependable solution for connecting PCs.
  • Enhanced performance
    Tested to support frequencies up to 550 MHz, this patch cable is capable of delivering stable and high-speed data transmission. The use of American Wire Gauge (AWG) 24 in its construction allows for optimal signal integrity, making it suitable for various networking environments.
  • Universal compatibility
    Featuring RJ-45 male connectors on both ends, the Cat6 Booted Unshielded (UTP) Network Patch Cable is compatible with a wide range of devices. Its adherence to RoHS compliant standards further ensures its suitability for use in diverse settings, promoting environmental sustainability.
C2G Cat6 Booted Unshielded (UTP) Network Patch Cable - patch cable - 5 m - black
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Molded, snagless, stranded
Length
5 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
24
Plated Connector
Gold
Length
5 m
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 550 MHz
Length: 5m
Colour: Black
Brand: C2G
