C2G 5m Cat5E 350 MHz Snagless Patch Cable - White
Quicklinx: 6BN2WS00 Mfr#: 83265
For Fast Ethernet networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat5e TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs are bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimizes Near-End Crosstalk (NEXT) levels. The molded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief.
  • High-quality connectivity
    The Cat5e Booted Unshielded (UTP) Network Patch Cable by C2G is designed with a 24 American Wire Gauge (AWG) and gold-plated connectors, ensuring reliable, high-speed data transmission up to 350 MHz. Its PVC jacket material and T568B wiring scheme provide durability and optimal network performance.
  • Versatile compatibility
    This patch cable is compatible with PCs, featuring male RJ-45 connectors on both ends for easy connection to a variety of network devices. The UTP technology and 4 pairs per cable design allow for efficient data transfer and minimal interference, making it suitable for various networking environments.
C2G Cat5e Booted Unshielded (UTP) Network Patch Cable - patch cable - 5 m - white
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Molded, snagless, stranded
Length
5 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
White
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
5 m
White
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 350 MHz
