C2G 5m Cat5E 350 MHz Snagless Booted Patch Cable - Yellow
Quicklinx: 69P4WS00 Mfr#: 83245
For Fast Ethernet networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat5e TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs are bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimizes Near-End Crosstalk (NEXT) levels. The molded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief.
  • Enhanced connectivity
    The Cat5e Booted Unshielded (UTP) Network Patch Cable by C2G ensures a reliable connection with its high-quality, gold-plated RJ-45 connectors. These connectors provide a secure link between devices, minimizing interference and maximizing performance for both home and office networks.
  • Durable design
    Featuring a robust PVC jacket and an American Wire Gauge (AWG) of 24, this network patch cable is designed for durability and long-term use. Its construction is tailored to withstand the rigors of daily connectivity demands, ensuring a stable and continuous network connection.
  • High-speed performance
    Tested to support frequencies up to 350 MHz, this CAT 5e cable facilitates high-speed data transmission. It's capable of supporting network applications that require bandwidth-intensive data transfer, making it suitable for a variety of networking needs.
C2G Cat5e Booted Unshielded (UTP) Network Patch Cable - patch cable - 5 m - yellow
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Molded, snagless, stranded
Length
5 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Yellow
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
5 m
Yellow
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 350 MHz
