For Fast Ethernet networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat5e TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs are bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimizes Near-End Crosstalk (NEXT) levels. The molded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief.
Enhanced connectivity
The Cat5e Booted Unshielded (UTP) Network Patch Cable by C2G ensures a reliable connection with its high-quality, gold-plated RJ-45 connectors. These connectors provide a secure link between devices, minimizing interference and maximizing performance. -
Durable design
Featuring a robust PVC jacket material and an American Wire Gauge (AWG) of 24, this patch cable is designed for durability and long-term use. Its construction is ideal for both commercial and residential applications, ensuring your network remains operational under various conditions. -
High-speed performance
With a tested frequency of up to 350 MHz, this network patch cable supports fast data transfer rates, making it suitable for high-speed Internet connections, video streaming, and online gaming. The T568B wiring scheme and UTP technology help in reducing crosstalk, ensuring a stable and fast connection.
- C2G Cat5e Booted Unshielded (UTP) Network Patch Cable - patch cable - 5 m - grey
- Patch cable - CAT 5e
- Technology
- Wiring Scheme
- T568B
- Wires per Cable
- 8 wires
- Molded, snagless, stranded
- Length
- 5 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Grey
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Plated Connector
- Gold
- Length
- 5 m
- Grey
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS - up to 350 MHz
C2G 5m Cat5E 350 MHz Snagless Booted Patch Cable - Grey
