C2G 5m Cat5E 350 MHz Snagless Booted Patch Cable - Green
Quicklinx: 69NQWS00 Mfr#: 83205
For Fast Ethernet networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat5e TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs are bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimizes Near-End Crosstalk (NEXT) levels. The molded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief.
  • High-quality connectivity
    The Cat5e Booted Unshielded (UTP) Network Patch Cable by C2G is designed with a PVC jacket and gold-plated connectors to ensure high-quality, reliable connectivity for all networking needs. With a wiring scheme of T568B, it provides a stable and secure connection.
  • Enhanced performance
    Featuring a tested frequency of up to 350 MHz and constructed with 24 American Wire Gauge (AWG) standards, this patch cable is engineered to facilitate superior performance for your network. The UTP technology and 4 pairs per cable configuration further enhance its capability to deliver smooth data transmission.
  • Universal compatibility
    Designed to be compatible with PCs, this network patch cable comes equipped with male RJ-45 connectors on both ends, ensuring a versatile and straightforward connection to a wide range of network devices.
C2G Cat5e Booted Unshielded (UTP) Network Patch Cable - patch cable - 5 m - green
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Molded, snagless, stranded
Length
5 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Green
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
5 m
Green
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 350 MHz
