C2G 5m Cat5E 350 MHz Crossover Patch Cable - Yellow
Quicklinx: 6BPBWS00 Mfr#: 83353
With a C2G Enhanced Cat5 350MHz Crossover Patch Cable and a network adapter, you can easily network two Windows-based computers in a Peer-to-Peer Networking configuration. In addition, this cable can be used for hub-to-hub, transceiver-to-transceiver or repeater-to-repeater Ethernet connections. C2G 350MHz crossover patch cables are labeled as crossover for easy identification.
  • High-quality connectivity
    The Cat5e Non-Booted Unshielded (UTP) Network Crossover Patch Cable is designed with 24 AWG wires and a durable PVC jacket, ensuring reliable connectivity and longevity. Its gold-plated connectors provide a secure connection and minimize interference, making it an ideal choice for networking needs.
  • Enhanced performance
    With a tested frequency of up to 350 MHz, this crossover cable supports high-speed data transmission. The T568B wiring scheme and UTP technology help reduce noise and crosstalk, enhancing your network's performance for both home and office environments.
C2G Cat5e Non-Booted Unshielded (UTP) Network Crossover Patch Cable - crossover cable - 5 m - yellow
Crossover cable - CAT 5e
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Stranded, uniboot
Length
5 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Yellow
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Stranded, uniboot
Length
5 m
Yellow
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 350 MHz
