With a C2G Enhanced Cat5 350MHz Crossover Patch Cable and a network adapter, you can easily network two Windows-based computers in a Peer-to-Peer Networking configuration. In addition, this cable can be used for hub-to-hub, transceiver-to-transceiver or repeater-to-repeater Ethernet connections. C2G 350MHz crossover patch cables are labeled as crossover for easy identification.
High-quality connectivity
The Cat5e Non-Booted Unshielded (UTP) Network Crossover Patch Cable is designed with 24 AWG wires and a durable PVC jacket, ensuring reliable connectivity and longevity. Its gold-plated connectors provide a secure connection and minimize interference, making it an ideal choice for networking needs. -
Enhanced performance
With a tested frequency of up to 350 MHz, this crossover cable supports high-speed data transmission. The T568B wiring scheme and UTP technology help reduce noise and crosstalk, enhancing your network's performance for both home and office environments.
- C2G Cat5e Non-Booted Unshielded (UTP) Network Crossover Patch Cable - crossover cable - 5 m - yellow
- Crossover cable - CAT 5e
- Technology
- Wiring Scheme
- T568B
- Wires per Cable
- 8 wires
- Stranded, uniboot
- Length
- 5 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Yellow
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Plated Connector
- Gold
- Stranded, uniboot
- Length
- 5 m
- Yellow
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS - up to 350 MHz
C2G 5m Cat5E 350 MHz Crossover Patch Cable - Yellow
