C2G 5m Cat5E 350 MHz Assembled Patch Cable - Black
Quicklinx: 6BKHWS00 Mfr#: 83045
Perfect for your home office or a large installation project, Enhanced Cat5E 350MHz Assembled Patch Cables from C2G distribute data, voice and video over today's advanced fast Ethernet and gigabit computer networks. These cables will handle bandwidth intensive applications up to 350MHz and beyond.
  • High-quality connectivity
    The Cat5e Non-Booted Unshielded (UTP) Network Patch Cable by C2G ensures a reliable connection with its gold-plated connectors and a tested frequency of up to 350 MHz. This combination not only provides a stable Internet connection but also minimizes interference, making it ideal for various networking needs.
  • Durable design
    Designed with a PVC jacket and an American Wire Gauge (AWG) of 24, this patch cable is built for durability. The robust construction ensures it can withstand the rigors of daily use, making it a reliable choice for both home and office environments.
  • Universal compatibility
    Featuring a T568B wiring scheme and RJ-45 connectors, this network patch cable is compatible with a wide range of devices. Whether connecting PCs, routers, or switches, users can expect seamless integration and performance.
C2G Cat5e Non-Booted Unshielded (UTP) Network Patch Cable - patch cable - 5 m - black
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Stranded, uniboot
Length
5 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Stranded, uniboot
Length
5 m
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 350 MHz
