C2G 5m 16 AWG Universal Power Cord (IEC320C13 to BS 1363)
Quicklinx: 6C4VWS00 Mfr#: 88516
Length: 5m
39 In Stock
£6.02 ex VAT
£7.22 inc VAT
Replace your overused or misplaced power cable, or just get some extra cords for convenience. This universal power cord is designed to work with most desktop PCs, monitors, scanners, printers and other devices that use the 3-pin shroud power connector. Plus this heavy-duty 16 AWG cord features a fully moulded design for maximum durability and long life. The female connector plugs directly into the device while the male connector plugs into a standard outlet.
  • Versatile compatibility
    Designed to power a wide range of PCs, this universal power cord seamlessly integrates with most computer systems, ensuring a reliable connection and power supply.
  • Durable design
    Crafted with a 16 American Wire Gauge (AWG) cable, this power cord is built for longevity and consistent performance, providing a dependable power solution for your computing needs.
C2G Universal Power Cord - power cable - BS 1363 to power IEC 60320 C13 - 5 m
Power cable
Molded
Length
5 m
Connector
Power BS 1363 - male
Connector (Second End)
Power IEC 60320 C13
Power cable
16
Molded
Length
5 m
Connector
Power IEC 60320 C13
Length: 5m
Brand: C2G
