Plug in the UL listed Universal Power Cord from C2G to replace your overused or misplaced power cables. Universal Power Cords are designed to work with most PCs, monitors, scanners, printers and other devices that use the 3-pin shroud power connector. All C2G power cables feature a fully molded design that provides maximum durability and long-life.
Versatile compatibility
Designed specifically for PCs, this universal power cord seamlessly integrates with a wide range of computer systems, ensuring a reliable power connection for your computing needs. -
Robust construction
Featuring a 16 AWG cable, this power cord is built to deliver enhanced durability and efficient power transmission, making it an ideal choice for both home and office environments.
- C2G Universal Power Cord - power cable - power CEE 7/7 to power IEC 60320 C13 - 5 m
- Power cable
- Molded, 90° connector
- Length
- 5 m
- Localisation
- Europe
- Connector
- Power CEE 7/7 - male
- Connector (Second End)
- Power IEC 60320 C13
- Black
- Limited lifetime warranty
- Power cable
- American Wire Gauge (AWG)
- 16
- Length
- 5 m
- Black
- Localisation
- Europe
- Connector
