This USB 2.0 USB-C to USB-Mini B cable is the perfect solution for connecting a camera, smartphone, tablet or other device that has a USB Mini B port to a computer, tablet or other device that has a USB Type-C port up to 4 metres away for USB 2.0 communication. The colour-coded USB Type-C connector allows this cable to be easily identified as a USB 2.0 cable and differentiated from other cables which may support a different feature set. With its robust design, the USB-C connector can be plugged in and un-plugged up to 10,000 times; six times more than a standard USB A Connector. Additionally, the USB-C connector is user-friendly and has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port. This cable supports a data rate up to 480Mbps for data transfer and sync with 5 volts and 1 amp of power for device operation and charging.
Efficient charging and syncing
This USB-C to Mini USB-B cable is designed to facilitate quick and efficient charging, alongside seamless data syncing capabilities. Its construction with American Wire Gauge (AWG) 24/30 ensures optimal performance for power delivery and data transfer. -
Durable design
Featuring color-coded connectors for easy identification, a nickel-plated shell for enhanced durability, and gold-plated connectors to resist corrosion, this cable is built for longevity. Its robust design ensures it can withstand the rigors of daily use while maintaining reliable connectivity. -
Universal compatibility
Designed to be compatible with PC, this cable supports a wide range of devices. Whether connecting to peripherals or charging devices, its versatility ensures it meets the needs of various user requirements.
- C2G 4m USB 2.0 USB Type C to USB Mini B Cable M/M - USB C Cable Black - USB-C cable - mini-USB Type B to 24 pin USB-C - 4 m
- USB-C cable
- Sync and charge, colour-coded connectors, nickel plated shell
- Length
- 4 m
- Connector
- Mini-USB Type B - male
- Connector (Second End)
- 24 pin USB-C - male
- USB / USB 2.0
- Black
- Limited lifetime warranty
- USB-C cable
- American Wire Gauge (AWG)
- 24/30
- Plated Connector
- Gold
- Length
- 4 m
- Black
- Connector
- USB / USB 2.0
