C2G 4m USB 2.0 USB C to USB Micro B Cable M/M - Black
Quicklinx: CHNNWS00 Mfr#: 88853
This USB 2.0 USB-C to USB-Micro B cable is the perfect solution for connecting a smartphone, tablet, or other device that has a USB-Micro B port to a computer, tablet or other device that has a USB Type-C port up to 4 metres away for USB 2.0 communication. The colour-coded USB Type-C connector allows this cable to be easily identified as a USB 2.0 cable and differentiated from other cables which may support a different feature set. With its robust design, the USB-C connector can be plugged in and un-plugged up to 10,000 times; six times more than a standard USB A Connector. Additionally, the USB-C connector is user-friendly and has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port. This cable supports a data rate up to 480Mbps for data transfer and sync with 5 volts and 1 amp of power for device operation and charging. Note: This cable is designed to support USB 2.0 communication and features and is not able to support USB 3.1 Gen 2 Communication and features.
  • Efficient charging and syncing
    The 4 m USB 2.0 USB Type-C to USB Micro B Cable M/M - USB C Cable Black is designed to support both sync and charge functionality, making it a versatile cable for connecting a wide range of devices. With its ability to handle data transfer and power delivery simultaneously, users can expect efficient charging and syncing of their devices without the need for multiple cables.
  • Durable design
    Featuring color-coded connectors and a nickel-plated shell, this cable is not only easy to identify among other cables but also offers enhanced durability. The gold-plated connector further ensures a reliable connection and superior signal integrity, providing a long-lasting solution for all your USB needs.
C2G 4m USB 2.0 USB Type C to USB Micro B Cable M/M - USB C Cable Black - USB-C cable - Micro-USB Type B to 24 pin USB-C - 4 m
USB-C cable
Sync and charge, colour-coded connectors, nickel plated shell
Length
4 m
Connector
5 pin Micro-USB Type B - male
Connector (Second End)
24 pin USB-C - male
USB / USB 2.0
USB-C cable
American Wire Gauge (AWG)
24/30
Plated Connector
Gold
Length
4 m
Connector
24 pin USB-C - male
USB / USB 2.0
