This USB 2.0 USB-C to USB-B cable is the perfect solution for connecting a printer, hub, or other device that has a USB B port to a computer, tablet or other device that has a USB Type-C port up to 4 metres away for USB 2.0 communication. This cable supports a data rate up to 480Mbps for data transfer and sync with 5 volts and 1 amp of power for device operation and charging. With its robust design, the USB-C connector can be plugged in and un-plugged up to 10,000 times; six times more than a standard USB A Connector. Additionally, the USB-C connector is user-friendly and has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port. The colour-coded USB Type-C connector allows this cable to be easily identified as a USB 2.0 cable and differentiated from other cables which may support a different feature set. This cable is designed to support USB 2.0 communication and features and is not able to support USB 3.1 Gen 2 communication and features.
Enhanced durability
Featuring a double-shielded structure and nickel-plated shell, this USB-C cable is designed for robust, long-lasting performance. Its construction ensures maximum protection against interference, making it ideal for both syncing and charging your devices. -
Universal compatibility
Designed to connect seamlessly with any PC, this cable boasts a versatile USB Type C to USB Type B connection. Its compliance with USB and USB 2.0 standards ensures it can handle a wide range of devices, from printers to external hard drives, providing a reliable link for all your data transfer needs. -
High-quality connectivity
Gold-plated connectors not only give this cable a premium look but also provide superior conductivity. This ensures fast, efficient data transfer and charging, coupled with reduced signal loss for high-performance syncing across all your devices.
 - C2G 4m USB 2.0 USB Type C to USB B Cable M/M - USB C Cable Black - USB-C cable - USB Type B to 24 pin USB-C - 4 m
 - USB-C cable
- Technology
 - Double shielded
 - Sync and charge, colour-coded connectors, nickel plated shell
- Length
 - 4 m
- Connector
 - 4 pin USB Type B - male
- Connector (Second End)
 - 24 pin USB-C - male
 - USB / USB 2.0
 - Black
 - Limited lifetime warranty
 - USB-C cable
- Technology
 - Double shielded
- American Wire Gauge (AWG)
 - 24/30
- Plated Connector
 - Gold
- Length
 - 4 m
 - Black
- Connector
 - USB / USB 2.0
