C2G 4-Port USB 2.0 Laptop Hub with .45m Blue LED Indicator Cable
Quicklinx: 6873WS00 Mfr#: 81647
The USB 2.0 4-port laptop hub expands your USB configuration and provides three extra ports for connecting peripherals. Small, lightweight and portable, the laptop hub can be readily used anywhere you go. It's fully USB 2.0 compliant to ensure compatibility with all USB peripherals, regardless of computer manufacturer or operating system. The LED indicator on the cable shows your hub is being powered, while the flip-up plastic cover protects your ports while not in use.
C2G USB 2.0 4-port Laptop Hub - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
4 x USB 2.0
5.1 cm x 3.8 cm x 2.5 cm
104 g
Blue
1-year warranty
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
4 x USB 2.0
4 x USB 2.0 Type A , 1 x USB 2.0
Blue
1 x USB cable - 45.7 cm
RoHS
5.1 cm
3.8 cm
2.5 cm
104 g
Limited warranty - 1 year
