Connect to mobiles, GPS systems, PDAs, and digital cameras by using the micro-USB connection on your computer or other USB device. The micro-USB connector is smaller and thinner than the previous USB Mini-b standard while offering better performance. Its small form factor is ideal for today's compact portable devices while easily transferring data or charging your device at a transfer speed up to 480 Mbps. This cable is compliant with USB 2.0 specifications.
Efficient connectivity
The C2G USB 2.0 A to Micro B Cable ensures a reliable connection between devices, featuring a 4-pin USB Type-A connector on one end and a 5-pin Micro-USB Type-B connector on the other. This design facilitates seamless data transfer and charging capabilities for a wide range of electronic devices. -
High compatibility
Compliant with USB and USB 2.0 standards, this cable is designed to work with a multitude of devices. Whether connecting to a smartphone, tablet, or other USB-enabled device, users can expect consistent performance and data integrity.
 - C2G USB 2.0 A to Micro B Cable - USB cable - USB to Micro-USB Type B - 4 m
 - USB cable
- Length
 - 4 m
- Connector
 - 4 pin USB Type A - male
- Connector (Second End)
 - 5 pin Micro-USB Type B - male
 - USB / USB 2.0
 - Black
 - Limited lifetime warranty
 - USB cable
- Length
 - 4 m
 - Black
- Connector
 - USB / USB 2.0
