C2G 3m Value Series™ S-Video Cable
Quicklinx: 63T8WS00 Mfr#: 80042
S-video cables from C2G are designed to connect S-video equipped components to your television. These cables are constructed with separate conductors to carry the Y-component and the C-component, providing better picture quality than a composite video cable. S-video cables are commonly used for DVD players, satellite receivers, S-VHS VCRs, camcorders and interface with S-video equipped televisions. S-Video cables also work with most PCs and notebooks with 7-pin TV-output jacks.
C2G Value Series video cable - S-Video - 3 m
Cable
Video cable - S-Video
Length
3 m
Connector
4 pin mini-DIN - male
Connector (Second End)
Molded
Cable Type
Video cable molded
Interface Supported
S-Video
Jacket Material
Flexible PVC
Length
3 m
Connector
Limited warranty - lifetime
