This USB 3.0 (USB 3.1 Gen 1) USB-C to USB-Micro B cable is the perfect solution for connecting a smartphone, tablet, or other device that has a USB-Micro B port to a computer, tablet or other device that has a USB Type-C port up to 3 metres away for USB 3.0 (USB 3.1 Gen 1) communication. The colour-coded USB Type-C connector allows this cable to be easily identified as a USB 3.0 (USB 3.1 Gen 1) cable and differentiated from other cables which may support a different feature set. With its robust design, the USB-C connector can be plugged in and un-plugged up to 10,000 times; six times more than a standard USB A Connector. Additionally, the USB-C connector is user-friendly and has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port. This cable supports a data rate up to 5Gbps for data transfer and sync with 5 volts and 1 amp of power for device operation and charging.
Enhanced durability
Featuring color-coded connectors and a nickel-plated shell, this USB-C cable is designed for both longevity and ease of use. Its robust construction ensures it can withstand the rigors of daily sync and charge activities. -
High-speed connectivity
Compliant with USB 3.0 and USB 3.1 standards, the cable supports fast data transfer speeds, making it ideal for quick syncing of large files. The gold-plated connector further enhances signal integrity, ensuring reliable performance. -
Universal compatibility
Designed to connect a wide range of devices, this cable features a 24-pin USB-C connector on one end and a 10-pin Micro-USB Type-A connector on the other, making it versatile for use with various gadgets.
 - C2G 3m USB 3.1 Gen 1 USB Type C to USB Micro B Cable - USB C Cable Black - USB-C cable - 24 pin USB-C to 10 pin Micro-USB Type A - 3 m
 - USB-C cable
 - Sync and charge, colour-coded connectors, nickel plated shell
- Length
 - 3 m
- Connector
 - 24 pin USB-C - male
- Connector (Second End)
 - 10 pin Micro-USB Type A - male
 - USB 3.0/ USB 3.1
 - Black
 - Limited lifetime warranty
 - USB-C cable
- American Wire Gauge (AWG)
 - 24/30
- Plated Connector
 - Gold
- Length
 - 3 m
 - Black
- Connector
 - USB 3.0/ USB 3.1
