C2G 3m USB 3.1 Gen 1 USB C to USB B Cable M/M – Black
Quicklinx: CHP8WS00 Mfr#: 88867
Length: 3m
Select:
More than 50 In Stock
£18.46 ex VAT
£22.15 inc VAT
Express delivery Order within the next 16 hours for delivery tomorrow
This USB 3.0 (USB 3.1 Gen 1) USB-C to USB-B cable is the perfect solution for connecting a hard drive, hub, or other device that has a USB B port to a computer, tablet or other device that has a USB Type-C port up to 3 metres away for USB 3.0 (USB 3.1 Gen 1) communication. The colour-coded USB Type-C connector allows this cable to be easily identified as a USB 3.0 (USB 3.1 Gen 1) cable and differentiated from other cables which may support a different feature set. With its robust design, the USB-C connector can be plugged in and un-plugged up to 10,000 times; six times more than a standard USB A Connector. Additionally, the USB-C connector is user-friendly and has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port. This cable supports a data rate up to 5Gbps for data transfer and sync with 5 volts and 1 amp of power for device operation and charging.
  • Lifetime warranty
    Length: 3.00 Meter
  • Warranty
    Lifetime
  • Colour
  • Length
    3 meter
C2G 3m USB 3.1 Gen 1 USB Type C to USB B Cable M/M - USB C Cable Black - USB-C cable - USB Type B to 24 pin USB-C - 3 m
USB-C cable
Sync and charge, colour-coded connectors, nickel plated shell
Length
3 m
Connector
9 pin USB Type B - male
Connector (Second End)
24 pin USB-C - male
USB 3.0/ USB 3.1
USB-C cable
Plated Connector
Gold
Length
3 m
Connector
24 pin USB-C - male
USB 3.0/ USB 3.1
Length: 3m
Brand: C2G
