This USB 2.0 USB-C to USB-Mini B cable is the perfect solution for connecting a camera, smartphone, tablet or other device that has a USB Mini B port to a computer, tablet or other device that has a USB Type-C port up to 3 metres away for USB 2.0 communication. The colour-coded USB Type-C connector allows this cable to be easily identified as a USB 2.0 cable and differentiated from other cables which may support a different feature set. With its robust design, the USB-C connector can be plugged in and un-plugged up to 10,000 times; six times more than a standard USB A Connector. Additionally, the USB-C connector is user-friendly and has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port. This cable supports a data rate up to 480Mbps for data transfer and sync with 5 volts and 1 amp of power for device operation and charging.
Efficient charging and syncing
The 3 m USB 2.0 USB Type-C to USB Mini B Cable M/M facilitates efficient charging and syncing capabilities, thanks to its compliance with USB / USB 2.0 standards. Its design ensures a reliable connection between devices, making it ideal for both power charging and data transfer. -
Durable design
Featuring color-coded connectors, a nickel-plated shell, and a gold-plated connector, this USB-C cable is designed for durability. The robust construction ensures optimal performance and reduces the risk of damage over time. -
Versatile connectivity
With a male mini-USB Type-B connector on one end and a male 24-pin USB-C connector on the other, this cable offers versatile connectivity options. It supports a wide range of devices, making it a practical choice for connecting various electronics.
 - C2G 3m USB 2.0 USB Type C to USB Mini B Cable M/M - USB C Cable Black - USB-C cable - mini-USB Type B to 24 pin USB-C - 3 m
 - USB-C cable
 - Sync and charge, colour-coded connectors, nickel plated shell
- Length
 - 3 m
- Connector
 - Mini-USB Type B - male
- Connector (Second End)
 - 24 pin USB-C - male
 - USB / USB 2.0
 - Black
 - Limited lifetime warranty
 - USB-C cable
- American Wire Gauge (AWG)
 - 24/30
- Plated Connector
 - Gold
- Length
 - 3 m
 - Black
- Connector
 - USB / USB 2.0
