C2G 3m USB 2.0 USB C to USB Micro B Cable M/M - Black
Quicklinx: CHNMWS00 Mfr#: 88852
This USB 2.0 USB-C to USB-Micro B cable is the perfect solution for connecting a smartphone, tablet, or other device that has a USB-Micro B port to a computer, tablet or other device that has a USB Type-C port up to 3 metres away for USB 2.0 communication. The colour-coded USB Type-C connector allows this cable to be easily identified as a USB 2.0 cable and differentiated from other cables which may support a different feature set. With its robust design, the USB-C connector can be plugged in and un-plugged up to 10,000 times; six times more than a standard USB A Connector. Additionally, the USB-C connector is user-friendly and has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port. This cable supports a data rate up to 480Mbps for data transfer and sync with 5 volts and 1 amp of power for device operation and chargin. Note: This cable is designed to support USB 2.0 communication and features and is not able to support USB 3.1 Gen 2 Communication and features.
  • Efficient charging and syncing
    This USB-C to Micro-USB cable supports both sync and charge functionality, making it a versatile choice for connecting a wide range of devices. It handles data transfer and power delivery efficiently, offering reliable performance for daily needs.
  • Durable design
    Featuring color-coded connectors, a nickel-plated shell, and a gold-plated connector, this cable is built for durability and long-lasting use. The selection of materials ensures a stable connection and reduces the risk of wear over time.
  • Universal compatibility
    The cable's compliance with USB and USB 2.0 standards, along with its USB-C and Micro-USB connectors, makes it compatible with various devices. It ensures seamless connectivity for PCs and other devices enabled with USB-C and Micro-USB.
C2G 3m USB 2.0 USB Type C to USB Micro B Cable M/M - USB C Cable Black - USB-C cable - Micro-USB Type B to 24 pin USB-C - 3 m
USB-C cable
Sync and charge, colour-coded connectors, nickel plated shell
Length
3 m
Connector
5 pin Micro-USB Type B - male
Connector (Second End)
24 pin USB-C - male
USB / USB 2.0
USB-C cable
American Wire Gauge (AWG)
24/30
Plated Connector
Gold
Length
3 m
Connector
24 pin USB-C - male
USB / USB 2.0
