This USB 2.0 USB-C to USB-B cable is the perfect solution for connecting a printer, hub, or other device that has a USB B port to a computer, tablet or other device that has a USB Type-C port up to 3 metres away for USB 2.0 communication. This cable supports a data rate up to 480Mbps for data transfer and sync with 5 volts and 1 amp of power for device operation and charging. With its robust design, the USB-C connector can be plugged in and un-plugged up to 10,000 times; six times more than a standard USB A Connector. Additionally, the USB-C connector is user-friendly and has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port. The colour-coded USB Type-C connector allows this cable to be easily identified as a USB 2.0 cable and differentiated from other cables which may support a different feature set. This cable is designed to support USB 2.0 communication and features and is not able to support USB 3.1 Gen 2 communication and features.
Efficient charging and syncing
The 3 m USB 2.0 USB Type-C to USB-B Cable M/M from C2G is designed to deliver both efficient charging and high-speed data transfer. With its sync and charge capability, this cable ensures your devices stay powered and up-to-date, making it an essential tool for any PC user. -
Durable design
Featuring a double-shielded structure with a nickel-plated shell and gold-plated connectors, this USB-C cable is built for durability and reliable connectivity. The color-coded connectors also make it easy to identify and use, ensuring a secure connection every time. -
Universal compatibility
Designed to be compatible with PCs, this cable supports a wide range of devices thanks to its USB 2.0 compliance. Whether connecting to a printer, external hard drive, or other peripherals, the versatile 24-pin USB-C and 4-pin USB Type-B connectors ensure a seamless connection.
- C2G 3m USB 2.0 USB Type C to USB B Cable M/M - USB C Cable Black - USB-C cable - USB Type B to 24 pin USB-C - 3 m
- USB-C cable
- Technology
- Double shielded
- Sync and charge, colour-coded connectors, nickel plated shell
- Length
- 3 m
- Connector
- 4 pin USB Type B - male
- Connector (Second End)
- 24 pin USB-C - male
- USB / USB 2.0
- Black
- Limited lifetime warranty
- USB-C cable
- Technology
- Double shielded
- American Wire Gauge (AWG)
- 24/30
- Plated Connector
- Gold
- Length
- 3 m
- Black
- Connector
- USB / USB 2.0
